DA200伺服在LED分光机上的应用
【摘要】本文主要介绍英威腾伺服凭借其高精度、高响应、高价值的强大功能及定制化服务,成功地应用在了LED分光机上,赢得了客户的高度认可。
【Abstract】This paper mainly introduces INVT servo with its high accuracy, high response, high value and customized service, is successfully used in LED machines, it has won a high degree of customer recognition.
【关键字】英威腾伺服;位置精度;响应速度;速度观测器
【Keywords】INVT servo; positional accuracy; response speed;Speed observer
阅读原文:DA200伺服在LED分光机上的应用.pdf
