德国赫优讯netIC IOT设备级物联网嵌入式产品的研究与应用
作者:夏玲月,邓梧鹏,杨宏庆(德国赫优讯自动化系统有限公司,上海 200010)
摘要:伴随着预测性维护和大数据分析的需求在自动化领域的日益增加,设备级过程数据的重要性也越来越突出。赫优讯推出的设备级物联网嵌入式研发产品netIC IOT,是基于netX 52多协议芯片研发的一款智能DIL-32封装通讯IC,集成通用对象接口,通过OPC UA和MQTT实现IoT通讯,并在同一根物理线缆上与实时以太网通讯并行地传输数据。netIC IOT采用netPROXY技术,基于对象的抽象层,面向应用程序开发,并通过netX Studio工程工具进行参数配置。
关键词:netIC IOT;OPC UA;MQTT;netPROXY技术;netX Studio
Abstract: With the increasing demand for predictive maintenance and big data analytics in the field of automation, the importance of device-level process data is becoming more prominent. Hilscher has launched device-level IoT embedded R&D product netIC IOT which is an intelligent DIL-32 communication IC based on the netX 52 multi-protocol chip. It integrates a common object interface and implements IoT communication through OPC UA and MQTT. Data is transmitted in parallel with real-time Ethernet communication on the same physical cable. NetIC IOT adopts netPROXY technology, based object abstraction layer and application-oriented development, and it is configured by netX Studio Engineering Tool.
Key words: netIC IOT; OPC UA; MQTT; netPROXY technology;netX studio
在线预览:德国赫优讯netIC IOT设备级物联网嵌入式产品的研究与应用
摘自《自动化博览》2019年9月刊
