智能工厂即插即用解决方案研究
作者:北京和利时智能技术有限公司 丁研
摘要:本文针对智能工厂动态扩展和设备动态接入的典型应用场景,提出了一种即插即用解决方案,并指出基于OPC UA的模型构建和配置自动生成服务是支撑该解决方案关键技术。借助即插即用技术,用户将能够有效的提升智能工厂工程实施的集成效率,降低实施成本,并缩短因工程实施而停工停产的周期。
关键词:智能工厂;OPC UA;即插即用
Abstract: Aiming at the typical application scenarios of smart factory dynamic expansion and equipment dynamic access,this paper proposes a plug and play solution, and point out that OPC UA-based model & discovery mechanism, and autoconfiguration technology. With the help of plug-play technology,users will be able to effectively improve the integration and engineering efficiency, reduce implementation costs, and shorten the period of shutdown due to project implementation.
Key words: Smart Factory; OPC UA; Plug-And-Play
在线预览:智能工厂即插即用解决方案研究
摘自《自动化博览》2019年12月刊
