核电DCS系统工厂测试与现场调试逻辑功能验证方案对比分析和研究
当前国内核电机组的DCS验证采用工厂测试和现场调试独立策划 的方式,国外三代核电(如EPR、AP1000等)的DCS系统采用工厂测试 与现场调试总体策划的测试模式。本文借鉴EPR、AP1000的整体策划实 践,通过对核电DCS系统工厂测试与现场调试逻辑功能验证方案进行对 比分析和研究,找出差异,为核电DCS系统工厂测试与现场调试全范围 功能测试实施打下基础,有利于核电DCS系统工厂测试、现场调试的优 化和质量提升,从而控制工期和成本。
 郭旭东,齐敏,宋玉霞    ★北京广利核系统工程有限公司
 摘要:当前国内核电机组的DCS验证采用工厂测试和现场调试独立策划 的方式,国外三代核电(如EPR、AP1000等)的DCS系统采用工厂测试 与现场调试总体策划的测试模式。本文借鉴EPR、AP1000的整体策划实 践,通过对核电DCS系统工厂测试与现场调试逻辑功能验证方案进行对 比分析和研究,找出差异,为核电DCS系统工厂测试与现场调试全范围 功能测试实施打下基础,有利于核电DCS系统工厂测试、现场调试的优 化和质量提升,从而控制工期和成本。
关键词:核电;DCS;逻辑;测试
Abstract: At present, the DCS verification of domestic nuclear power  units is planned independently by DCS factory test and nuclear power  factory debugging. The DCS system of three generations of foreign  nuclear power plants (such as EPR, AP1000, etc.) adopts the test mode  of overall plan of factory test and nuclear power factory debugging.  Based on the overall planning practice of EPR, AP1000, this paper  compares and analyzes the verification scheme of logic function  between plant test and field debugging of nuclear DCS system, finds  out the difference and lays a foundation for the implementation of fullrange functional test of nuclear power DCS system factory test and  field debugging, which is conducive to the optimization and quality  improvement of nuclear power DCS system factory test and field  debugging, so as to the control of construction period and cost.
Key words: Nuclear power plant; DCS; Logic; Test
点击预览:核电DCS系统工厂测试与现场调试逻辑功能验证方案对比分析和研究.pdf
摘自《自动化博览》2021年5月刊
