核电安全级数字化仪控系统内存诊断设计与实现
核电厂数字化仪控系统根据标准要求需要对内存进行诊断。为了 解决物理内存地址操作问题,提高内存诊断覆盖率,并提升诊断效率, 设计了一种基于实时操作系统的内存诊断方法。采用March C-算法,诊 断范围可覆盖全部内存,在不影响操作系统中其他进程执行的情况下, 能够快速、安全地检测内存。该方法已经应用在防城港核电厂3# 、4#机 组的事故后监视系统中,对我国后续核电厂数字化仪控系统的开发具有 借鉴和指导意义。
作者:北京广利核系统工程有限公司 马忠刚,李萌,张智慧,石桂连,王晓伟
摘要:核电厂数字化仪控系统根据标准要求需要对内存进行诊断。为了 解决物理内存地址操作问题,提高内存诊断覆盖率,并提升诊断效率, 设计了一种基于实时操作系统的内存诊断方法。采用March C-算法,诊 断范围可覆盖全部内存,在不影响操作系统中其他进程执行的情况下, 能够快速、安全地检测内存。该方法已经应用在防城港核电厂3# 、4#机 组的事故后监视系统中,对我国后续核电厂数字化仪控系统的开发具有 借鉴和指导意义。
关键词:核电厂;数字化;仪表与控制;内存诊断;March C;堆栈检查
Abstract: The digital I&C system of nuclear power plant needs to  diagnose the memory according to the requirements of the standard.  In order to solve the problem of physical memory address operation,  improve the memory diagnosis coverage, and improve the diagnosis  efficiency, a memory diagnosis method based on real-time operating  system is designed. Using the March C- algorithm,the diagnosis range  can cover all the memory, and the memory can be tested quickly and  safely without affecting the operation of other application software  in the operating system. This method has been applied to the postaccident monitoring system of Fangchenggang nuclear power plant  No.3 and No.4 units, and has reference and guiding significance for  the development of my country's subsequent nuclear power plant I&C  system.
Key words: Nuclear power plant; Digitization; Instrumentation and  control; RAM diagnosis; March C; Stack check
在线预览:核电安全级数字化仪控系统内存诊断设计与实现.pdf
摘自《自动化博览》2021年8月刊
