新疆送变电有限公司 黄浦江,李辉,李永江
摘要:文章基于边缘计算提出了一种新的高压输电线路巡检数据实时处理技术。该技术采用广义幂变换公式对数据进行优化处理,提取数据特征进行数据融合,引入冗错算法进行数据识别,并构建了边缘计算的高压输电线路巡检数据处理模型,从而实现了数据实时处理。实验结果表明,相较于传统技术,本文所提技术在响应时间、数据稳定性及处理效率等方面均表现出明显优势,尤其适用于高压输电线路巡检中的智能化数据处理需求。该技术不仅提升了巡检数据的处理效率,还为电力系统的智能运维提供了有力的技术支持,具有广阔的应用前景。
关键词:边缘计算;高压输电线路;巡检数据;实时处理
Abstract: This article proposes a new real-time processing technology for high voltage transmission line inspection data based on edge computing. The generalized power transformation formula is used to optimize the data processing, extract data features for data fusion, introduce redundancy error algorithm to achieve data recognition, and construct an edge computing- based high voltage transmission line inspection data processing model, thereby achieving real-time data processing. Experimental results show that the technology proposed in this paper has obvious advantages over traditional technologies in terms of response time, data stability and processing efficiency, especially suitable for intelligent data processing requirements in high voltage transmission line inspections. This technology not only improves the processing efficiency of inspection data, but also provides strong technical support for the intelligent operation and maintenance of the power system, and has broad application prospects.
Key words: Edge computing; High voltage transmission line; Inspection data; Real-time processing
在线浏览:
应用边缘计算的高压输电线路巡检数据实时处理技术研究.pdf
摘自《自动化博览》2026年第一期暨《2026具身智能专刊》
