德图saveris-实现测量数据的全自动监测
  • 企业:控制网     领域:运动控制与伺服系统     行业:机械
  • 点击数:3675     发布时间:2009-05-07 17:00:48
  Simon Wassereit is the Facility Manager for a large insurance company. In the past few months, this has not been a pleasant task. Above all, the damages in the server room are worrying. But in addition, the complaints last week from the Board of Directors' floor when the temperatures in the offices were much too low in the mornings didn't escape his notice.
  Simon Wassereit是一家大型保险公司的物业经理。在过去的几个月里,物业经理的工作可不是件令人开心的差事。服务器机房的问题令人担忧,而且来自董事会的抱怨也令人头痛:这一楼层早晨的温度过低。
  Naturally, this is all an issue for the automated building services and building control: Here it must be ensured that the required temperature and humidity values dominate, at all times and everywhere. However, no individual room control was built in at that time due to cost concerns, which means that the air conditioning supplies large office and server room areas without differentiating. And how should the supplier for building control be shown that a mistake was made?
  这自然是和楼宇的自动化服务和控制有关的。在这里任何时间任何地点都必须确保要求的温度和湿度,但是考虑到实际的费用,不可能每个房间都建立这样的控制系统,这就意味着不管是办公室,还是服务器机房,空调系统是一视同仁的。而且要如何向供应商解释这个问题?
  In server rooms and office buildings, the protection of the valuable inventory is extremely important. To do this, the indoor ambient conditions must be monitored, i.e. temperature and humidity conditions must be kept at a constant level.
  在服务器机房和办公室里面,对于贵重资产的保护是相当重要的,所以室内的环境条件必须得到监测,温湿度的状况需保持的一个恒定的水平上。
  Reliable online monitoring and limit value alarms可靠的在线监测和限值报警
  Problems such as Mr Wassereit's often occur in office buildings and computer centres:
    Temperature and humidity values should be reliably measured and documented as evidence for acceptance and even for legal disputes, as applicable, as well as for personal documentation.
  If defined limit values are breached, an alarm should be issued immediately so that counter measures can be implemented without delay. Damages must be avoided instead of being expensively corrected after they occur.
  Wassereit所碰到的问题在办公建筑和电脑机房中是很常见的:
  持续监测温湿度值,并对结果进行存档,以便作为验收或者法律争端的证据,当然也可作为个人存档只用如果超过限值,需及时发出报警信号,以便能够及时采取相关措施,在付出更为昂贵的代价之前就将损害减至最低。
  In practice, the term "measurement data monitoring" has emerged for these applications. Instead of manual measurement data collection and the recording of random sample values in tables, measurement, recording and documentation as well as the issue of alarms are performed fully automatically here.
  实际上,“测量数据监测”就是为此应运而生的,不用再手工进行测量数据的收集,样本值的采集测量和记录以及归档整理,包括报警也实现了完全的自动化。
  testo Saveris, the new monitoring system for measurement data, is oriented towards these requirements. A selection of precise temperature and moisture probes is available for the rooms. The measurement data is saved decentrally in the battery-operated probes and is regularly radioed to a "testo Saveris base station" – loss of data is out of the question. Alternatively, the values can also be transferred via Ethernet. The base station has an extensive memory as well as the most varied possibilities for issuing alarms, from visual signals to sending an SMS to a mobile phone.
  Saveris测量数据监测系统可以完全满足这些要求。精挑细选的精密探头可用于橱柜和房间,无线探头由电池供电,测量数据可以实现非集中存储,然后探头会将数据以固定的时间频率发送至“德图saveris基站”,当然,数据也可以通过以太网的方式传输,基站拥有海量的数据存储内存,可以进行多种方式的报警,视频信号到发送短信到您的手机上等等。
  System overview: The wireless probes (1) send the recorded measurement values to the base (4), which stores all values centrally. A router (2) can be used to improve the wireless transfer under difficult building conditions. By connecting a converter (3) to an Ethernet socket, the signal from a wireless probe can be converted to an Ethernet signal. In addition to wireless probes, Ethernet probes (6) can also be used which can be directly connected to the Ethernet (5).
  The measurement data can be transferred to a PC (7) either by USB or Ethernet. Analysis and documentation of the measurements are then carried out quickly and easily with the testo Saveris-Software (8).
  系统纵览:无线探头 (1) 将已记录的测量数据发送至基站 (4), 基站会对其进行数据集中存储. 路由器 (2) 可在无线信号受到建筑物影响的情况下对信号进行加强和改善. 通过一个连接至以太插槽的转换器 (3),无线探头发出的无线信号可转换至以太讯号., 除无线探头外,以太探头也可在系统中进行使用,且以太探头(6)可直接与以太网进行连接。
  测量数据可经由USB 或以太网传输至电脑 (7). 通过使用00软件(8).我们可以快速而轻松地对测量结果进行分析和存档。
  Fast and cost-effective installation thanks to radio technology
  Transferring measurement data via radio enables a fast and cost-effective installation. Instead of complex cable routing from room to room, the locations can be chosen freely. With the example of office climate monitoring, you can avoid penetrating the walls with cables. The radio probe or alternatively an Ethernet probe is simply positioned within the room.
  无线电技术:安装工作经济迅速
  通过无线电传输数据的方法可以实现省时省钱的快速安装,测量点可自由选择,无需进行复杂的布线工作。以对办公环境的监测来说,无需为了布线打通墙体,将无线或以太探头直接放置在房间内即可。
  测量地点和测量数据之间的联系可在软件上简单清晰地看到,机器和房间的照片可以以图片的方式得到存储。不同的测量数据会在探头的位置上分别显示出来(显示单位可选°C/rF% 或 °F/RH%)
  Time is money, even in Facility Management: fast commissioning must therefore be guaranteed. If the installation of a monitoring system requires hours and days, even for well-trained building technicians, it completely fails the practical test. This was effectively implemented with testo Saveris to allow a prompt system setup for everyone:
  时间就是金钱,即便是物业管理方面也是如此。我们要保证最快速度地完成试运行,如果一个监测系统的安装工作需要好几个小时甚至几天,即便是对训练有素的建筑技工来说,这也是通不过实际考验的。而德图填补了这个不足,任何人都可以轻松完成这个先进系统的设定。
  The transmission path from the probe to the testo Saveris base station is established within seconds by pressing a button.
  一键即可完成由探头至基站的传输
  Step-by-step establishment of the probe network and definition of the limit values is completed quickly and easily with the aid of an "installation wizard" in the testo Saveris software.
  通过saveris软件的安装向导一步步完成探头网络的设立和限值的设定,轻松而快速
  Curve or table view as well as report printing is also possible at the push of a button in the software.
  软件中一键完成图表曲线图和生成报告的打印工作。
  Automated documentation and graphic presentation of the readings
  Unlike previously available monitoring systems, the user is not forced to provide a continuously running PC with testo Saveris. Entire series of measurements can be recorded and monitored via the testo Saveris base station alone – even for months at a time. Documentation and analysis using the testo Saveris software are only performed when required.
  自动完成数据的归档和读数的图表式呈现
  不同于之前的那些监测系统,用户无需一直运行电脑。整个测量工作的记录和监测都可通过基站单独完成,即便是长达几个月的连续监测都可轻松胜任。只有在需要的时候,我们才要打开saveris的软件进行归档和分析。
  Furthermore, you can select a continuous recording with curve representation on the PC screen or the measurement data representation in front of a background picture that can be freely integrated. You can thus recognize at a glance which readings dominate at which locations.
  此外,您也可以选择用波形图的方式在电脑上显示连续的测量值,背景图片也可自由整合,每个测量点的测量值可以轻松一览无余。
  Simon Wassereit walks calmly through the modern foyer of the insurance building. Last week he invested in a testo Saveris system with 18 probes, eight for the server rooms and ten for rooms with a "critical" climate. The installation took only a little time and the documentation and issue of alarms have functioned smoothly and automatically ever since. If the values exit the required range once, the caretaker is immediately alerted via mobile phone and inspects the air conditioning and – if necessary – calls the air conditioning mechanics. And for the Board of Directors, Mr Wassereit will compile a report at the end of the year with just a few mouse clicks that shows the readings from the past months. "To learn from criticism" – that is high art: even in Facility Management.
  现在Simon Wassereit沉着自信地走在保险大楼现代化的大厅里,上周他订购了一个saveris系统,18个探头,8个给服务器机房,10个留给了“重要”的办公室房间。安装工作非常迅速地完成了,自动记录和报警工作也进行地非常流畅。一旦超过限值,相关负责人就会收到手机报警,可及时检查环境情况,如有必要,可以向空调系统的技术工程人员求助。等到年底,Patrick 只要轻点几次鼠标就可以过去几个月的的数据汇编给董事会的人。“在批评中进步”这是高超的艺术,即便是对物业管理也是如此。
