作者:杨冬丽,朱启勇,李欣(浙江巨化热电有限公司,浙江 衢州 324000)
摘要:本文就某热电厂某型号汽轮发电机因发电机侧支持轴承油膜涡动引 起的汽轮机发电组连续跳停进行分析总结。该型汽轮机为高温、高压、单 缸、单抽、背压式机组。本文对引起油膜涡动的机理进行阐述,采用了频 谱分析技术对震动原因进行分析,确定了引起机组振动的诱因。
关键词:汽轮发电机组;振动;轴承;油膜涡动;频谱分析
Abstract: This paper analyzes and summarizes the continuous trip of a  steam turbine generator unit caused by the oil film whirl of the support  bearing on the generator side in a thermal power plant. The type of the  steam turbine is the high temperature and high pressure, single cylinder,  single extraction and back pressure. In this paper, the mechanism of oil  whirl is discussed. The frequency spectrum analysis technology is used  to analyze the cause of vibration. The cause of vibration is determined.
Key words: whirl;Spectrum analysis
在线预览: 一起油膜涡动引起的汽轮发电机组轴系振动分析.pdf
摘自《自动化博览》2021年8月刊
 今日头条
今日头条 官方微信
                        官方微信
                     官方抖音
官方抖音
         北京市公安局海淀分局备案号:11010802023656号
