ABB
CAIAC 2025
和利时K系列硬件在寿光电厂的应用
  • 企业:     行业:电力
  • 点击数:1005     发布时间:2019-06-29 10:33:38
作者:肖恒(神华国华寿光发电有限责任公司,山东 寿光 262714)
摘要:杭州和利时自动化有限公司DCS控制系统K系列硬件自研发成功,在电力行业百万等级机组首次应用在了神华国华寿光电厂一期(2×1000MW)工程,机组投产以来,通过实际应用与维护,和利时K系列硬件较和利时以往SM系列硬件有较多优势,提高了设备可靠性,降低了设备故障率,减少了生产人员的维护量及电厂维护成本。
关键词:K系列;硬件;首次;应用
Abstract: The Hollysys K series hardware for DCS control systems, which is developed by Hollysys Automation Co., Ltd.in Hangzhou, has been successfully applied to the Shenhua Guohua Huashou Photoelectric Power Plant (2 x 1000MW)project for the first time in the power industry. The new K series hardware has more advantages than the previous SM series hardware. Since the unit was put into operation, the reliability of equipment has been improved, the failure rate of equipment has been reduced. Moreover, the maintenance quantity of the production personnel and the maintenance cost of the power plant have also been reduced.
Key words: K series; Hardware; First time; Application
在线预览:和利时K系列硬件在寿光电厂的应用
摘自《自动化博览》2019年6月刊
