A New Approach for Automation of Distributed Systems
  • 企业:控制网     领域:工业以太网     行业:其他
  • 点击数:2186     发布时间:2004-09-20 14:31:00
Reinhard Langmann
        The concept Lean Web Automation (LWA) describes a new approach for web-based operation of automation devices in distributed systems, which can be used flexible by means of compact and low-cost software without installation expense on the client side. A dynamic process data transfer in the TCP/IP network is implemented by a javabased application model. This model uses a process data proxy to create at web clients an interface to process data of a remote automation device. A first practical realization of the LWA is the software toolkit Web Access Kit for OPC, which uses OPC as the interface to the process.
1  Initial position
        Since approx. 2 - 3 years, under the keyword
