基于数字孪生技术的电力通信机柜实时状态可视化技术探究
  • 企业:     行业:电力     领域:数字孪生
  • 点击数:3253     发布时间:2026-02-10 12:17:50
针对电力通信机柜实时状态监控与管理的复杂性问题,本文提出了一种基于数字孪生技术的可视化解决方案。该方案通过构建与物理机柜高度相似的数字模型,并利用先进的传感器技术和数据处理算法,能够实时采集并传输机柜的运行状态数据。利用数字孪生技术可实现对电力通信机柜内部结构和运行状态的直观展示,使得管理人员能够迅速掌握机柜的整体情况和潜在风险。同时,该技术还支持对机柜内设备的远程监控和配置,大大提高了运维效率。实验分析结果表明,基于数字孪生技术的电力通信机柜实时状态可视化技术不仅提高了机柜管理的智能化水平,还有效降低了故障发生率和维修成本。该技术能够直观显示机柜内各类设施的实时数据和状态信息,并支持多种告警方式,实现了对机柜运行状态的全面监控和优化管理。
国网河南省电力公司内黄县供电公司 杨凯,胡志刚,张晓庆,刘雅青,平国文
摘要:针对电力通信机柜实时状态监控与管理的复杂性问题,本文提出了一种基于数字孪生技术的可视化解决方案。该方案通过构建与物理机柜高度相似的数字模型,并利用先进的传感器技术和数据处理算法,能够实时采集并传输机柜的运行状态数据。利用数字孪生技术可实现对电力通信机柜内部结构和运行状态的直观展示,使得管理人员能够迅速掌握机柜的整体情况和潜在风险。同时,该技术还支持对机柜内设备的远程监控和配置,大大提高了运维效率。实验分析结果表明,基于数字孪生技术的电力通信机柜实时状态可视化技术不仅提高了机柜管理的智能化水平,还有效降低了故障发生率和维修成本。该技术能够直观显示机柜内各类设施的实时数据和状态信息,并支持多种告警方式,实现了对机柜运行状态的全面监控和优化管理。
关键词:数字孪生技术;电力通信;机柜;可视化
Abstract: In response to the complexity of real-time status monitoring and management of power communication cabinets, a visualization solution based on digital twin technology is proposed. This solution constructs a digital model highly similar to the physical cabinet, using advanced sensor technology and data processing algorithms to collect and transmit the operating status data of the cabinet in real time. The digital twin technology enables intuitive display of the internal structure and operating status of power communication cabinets, allowing managers to quickly grasp the overall situation and potential risks of the cabinets. At the same time, this technology supports remote monitoring and configuration of equipment inside the cabinets, significantly improving the operation and maintenance efficiency. Finally, the experimental analysis results show that the real-time status visualization technology of power communication cabinets based on digital twin technology not only improves the intelligence level of cabinet management but also effectively reduces the occurrence rate of faults and maintenance costs. This technology can visually display real-time data and status information of various facilities inside the cabinets, supports multiple alarm methods, and realizes comprehensive monitoring and optimized management of the cabinet's operating status.
Key words: Digital twin technology; Power communication; Cabinet; Visualization
在线浏览:基于数字孪生技术的电力通信机柜实时状态可视化技术探究.pdf
摘自《自动化博览》2026年第一期暨《2026具身智能专刊》
