艾讯宏达重磅推出英特尔B751芯片组工业母板SYM76990VGGA
  • 点击数:1733     发布时间:2012-07-02 18:02:48
艾讯宏达重磅推出英特尔B751芯片组工业母板SYM76990VGGA,艾讯宏达SYM76990VGGA支持LGA1155英特尔i3/i5/i7处理器。10个串口,特别适用于高铁/地铁自动售票机、ATM机、自助终端机等金融自动化及高端工控机领域。
        艾讯宏达最新推出英特尔B75芯片组Micro-ATX主板SYM76990VGGA。SYM76990VGGA采用英特尔B75芯片组,支持LGA1155英特尔i3/i5/i7处理器。最大支持32GB DDR3 内存。集成2个PCI-E千兆网络控制器, 12个USB接口。支持1个PCIe 16X,1个PCIe 4X,4个PCI扩展槽。SYM76990VGGA能够支持10个串口,特别适用于高铁/地铁自动售票机、ATM机、自助终端机等金融自动化及高端工控机领域。
>> System
Processor                            LGA1155 for Intel Core i3/i5/i7/Pentium/Celeron Processors
                                           Support SandyBridge and Ivy Bridge CPU
Chipset                               Intel B75 PCH (Q77 by option)
DRAM                                  4 x 240pin DDR3 1666MHz DIMM up to 32GB
BIOS                                   8MB AMI Flash ROM
Power Supply                      Standard ATX power
Watchdog                            Watchdog timer function
Dimension                            244mm x244mm
>> I/O Ports
HDD                                    1 x SATA 3.0 + 5 x SATA 2.0(RAID0/1/5/10 support by Q77 Option)
Serial Port                            9 x RS232 , 1 x RS232/422/485 (Auto Flow control function) Parallel                                1 x LPT port support with ECP/EPP/SPP mode
Audio                                   Realtek ALC892 High Definition Audio, line-out, line-in and MIC
Keyboard/Mouse                  1 x mini-DIN port for PS/2 Keyboard and Mouse
LAN                                    1 x Realtek 8111E PCI-E Gigabit controller
                                          1 x Intel 82579V PCI-E Gigabit controller
USB                                    8 x USB2.0 + 4 x USB 3.0
Digital I/O                            1 x 8 bits Digital I/O connector
Expansion                            1 x PCI-Ex16,  1 x PCI-Ex4, 2 x PCI slots
VGA                                    1x VGA port ,2048x1536 @ 75Hz max Resolution
DVI                                     1 x DVI-D port ,1920 x 1200@60Hz max Resolution
HDMI                                   1 x HDMI port ,1920 x 1200@60Hz max Resolution,  (Co-lay COM port Interface)
>> Environment
Operation Temperature         0°~60°C(32°~140°F)
Humidity                              10~90%
产品详情请登录艾讯宏达网站www.grantech.com.cn,或来电咨询。
