New Open Board Digital Temperature Controller 5R7-570 Announced by Xinmeiya Technology
Xinmeiya Technology is a distributor of Oven Industries in the PRC. Oven Industries features a new electronic temperature controller with easy-to-use software.
新美亚公司公布了其新款开放式面板数字温控器5R7-570。新美亚公司是Oven Industries 在中国的独家经销商。Oven公司重点推出了其新款具有易读软件的电子温控器。
The 5R7-570(A) RoHS compliant open board electronic temperature controllers are specifically de-signed with a proportional integral control algorithm to provide the most precise control to thermoelectric modules (Peltier) at the most economical price. The H-bridge temperature control provides a seamless transition between heating and cooling eliminating dead spots. Green LED for heat and blue LED for cooling indicate mode and simultaneous illumination indicates the load circuit is off due to an open sensor. Pulse width modulation controls the power level in the thermoelectric module at a base frequency of 1Khz. Power resolution is one of ±250 steps in the load circuit control. This small package temperature controller 1.75" x 3.5" X 3" with input voltage: 6 to 28VDC, Output Voltage: 0 to 36VDC, Load Current 0.1 to 12.5 Amps, 450W output power control, control stability: ± 0.1°C and temperature range of -20 to 150°C.
符合RoHS的开放式面板数字温控器5R7-570具有专门设计的比例积分控制运算,使它能够对热电模块提供最精准的控制(Peltier),而且价格最经济。H桥温度控制提供了制冷和制热的无缝过渡,并且无死点。绿色LED显示制热模式,蓝色LED显示制冷模式,由于开路传感器而同步照明指示负载电路是关闭的。脉冲宽度调控把热电模块的功率水平控制在1Khz基本频率。分辨率就是指负载电路控制中的±250步。该小型封装温度控制器尺寸1.75" x 3.5" X 3",输入电压:6-28VDC,输出电压:0-36VDC,负载电流:0.1-12.5Amps, 输出功率控制450W, 控制的稳定性:±0.1°C温度范围20至150°C.
FEATURES特性
• Universal AC Input
全电压输入
• Isolated Power Supply
隔离型电源
• PC Programmable
PC可编程界面
• RS232 Communication Port
RS232串口
• Setup via operator interface or serial link GUI
通过操作界面或串行通信GUI设置
• Non-Volatile Memory
非易失性存储器
• Set temp range determined by thermistor type
由电热调解器类型决定温度范围的设置
• Open Circuit Protection
断路保护
ACCESSORIES附件
Display Model 5R6-576: 4 digit LED temperature read out
(A) with remote set temp pot and knob with dial scale
Temperature Sensor
显示模式5R6-576: 4位数LED温度读出
远程设置温度和旋钮刻度盘
温度传感器
Oven Industries supplies custom electronic temperature controllers and sensors that serve an array of clients, from aerospace, automotive, biomedical, defense markets, medical and semiconductor. From industrial temperature controllers to programmable sensors, Oven Industries creates many detailed and customized solutions for clients, designed by an expertly trained staff of engineers.
Oven公司为很多客户提供定制的温度控制器和传感器,这些客户来自各行各业,如:航空航天,汽车制造,生物医学,军用市场,医学和半导体。从工业用温度控制器到可编程传感器,Oven公司的专家级水准工程师为客户创造了大量详尽的定制解决方案。
For more information about the 5R7-570 controller, visit:
关于5R7-570控制器的更多信息,请参考以下网站:
http://www.xinmeiyatech.com
http://www.ovenind.com/bv/Products/5R7-570-Electronic-Temperature-Controller__5R7-570.aspx
Media Contact
Aileen Sun
+86(27)88161550
aileen.sun@xinmeiyatech.com
