ABB IRB6640激光飞行焊演示单元
  • 厂商:ABB机器人部
  • 点击数:7149     发布时间:2015-06-15 11:27:00
使用机器人IRB6640,机器人和扫描振镜结合的激光飞行焊接能在大工作范围内带来高柔性和高效能,无需额外的主机即可协调处理扫描振镜和机器人运动实现飞行焊接。
    使用机器人IRB6640
    ABB robot and laser scan head cooperated for flexibility and productivity in large working area
    No need of a master PC to coordination of scan head and robot motion for on-the fly welding
    简单易用且内置有机器人运动和激光设备接口的专用飞行焊接指令
    Easy of use specific welding instruction enhanced robot motion and laser interface
    在线调试工具RLW Analyst 和 离线编程工具 RobotStudio Add-in可进行快速、强健的编程调试
On-line tool RLW Analyst and off-line tool RobotStudio Add-in for fast and robust commissioning
    新一代大型机器人IRB 6700的点焊应用
    Spot welding with new generation large robot IRB 6700
    可靠且兼具成本效益的大型机器人IRB 6700
    Reliable and cost effective large robot IRB 6700
    SafeMove™安全选件开启人机协作新时代
    SafeMove ™enable the truly human-machine collaboration
    配置完善的即用型机器人功能包为高品质高性能点焊提供助力
    Fully configured, ready-to use robot packages for high quality and high performance spot welding
    采用Lean ID增加Dress pack使用寿命
    Available with Lean ID to increase dress pack lifetimes
    性能卓越的模块化点焊枪ABB FlexGun
    High performance and modular spot welding gun ABB FlexGun
    快速、功能丰富的ABB电极修磨器
    High process speed and wide range ABB electrode tip dresser
    IRB 1520ID弧焊
    IRB 1520ID arc welding
    弧焊专用中空臂机器人IRB 1520ID
    Dedicated arc welding robot IRB 1520ID
    采用第二代TrueMove™ & QuickMove™ 技术实现了路径精度最优化和两次焊接间的加速度最大化
    Outstanding path accuracy and maximum acceleration between welds
    软管束与焊接电缆分别同上臂和底座紧密集成使得机器人在狭小区域的运动更加灵活
    Available with ID for easy accessing in narrow spaces for more flexible movements.
    高可靠性的碰撞检测功能保护设备及工件
    High reliability collision detection solution protect equipment and work pieces
    IRB 1200迷宫大作战
    Compete with IRB 1200 in Maze
    采用最具成本效益的小型机器人IRB 1200
    A compact, flexible, fast and functional small industrial robot
    兼顾紧凑性和有效工作范围优势
    Long reach while providing compactness
    速度提高10%,优异的精准度与敏捷性
    10% shorter cycle times with superior accuracy and agility
    配备新一代的高性能的紧凑型控制柜
    Equipped with the new generation compact controller
