Emerson推出新型多相流量计,给客户提供灵活、简单且成本更经济的监控手段
  • 厂商:艾默生
  • 点击数:4519     发布时间:2016-10-14 18:26:00
MPFM 2600 M 旨在帮助客户控制成本和提高效率及产能, 并使较小的油田可以更好地运营下去。”艾默生自动化解决方案Roxar副总裁兼总经理Patrick Babka表示,“对于每个油井需要一个多相流量计的应用来说,这款流量计是理想之选;通过该流量计,操作人员可以精确、成本经济地追踪来自各个井口的多相流。
Third generation Roxar MPFM 2600 M improves measurement and reliability
第三代 Roxar MPFM 2600 M 改善了测量和可靠性
STAVANGER, NORWAY (10 October 2016) -- Emerson Automation Solutions has introduced the Roxar MPFM 2600 M multiphase flow meter. The Roxar MPFM 2600 M is a flexible and easily manageable wellhead measurement solution based on a field-proven technology platform. The meter meets the needs of many challenging applications and can be a cost effective solution for more constrained budgets. The meter is ideal for customers with direct and continuous wellhead multiphase flow monitoring needs.
挪威斯塔万格(2016年10月10日)--艾默生自动化解决方案推出新型Roxar MPFM 2600 M 多相流量计。这款流量计基于经过实践验证的技术平台,可以为客户提供灵活、易于管理的井口测量解决方案。该流量计可以满足多种挑战性应用需求,并且可以为预算紧张的客户提供一种成本经济的解决方案。这款流量计是客户进行直接、连续井口多相流量监控需求的理想之选。
The Roxar MPFM 2600 M is part of the scalable Roxar multiphase product family and provides flexibility as fields mature and conditions change. The compact meter can be easily retrofitted in the field, delivers straightforward installation and commissioning, and has been specifically designed to meet operators’ capital expenditure and varying field requirements.
Roxar MPFM 2600 M 是具有可扩展性的Roxar 多相流量计产品系列的一部分,它可提供灵活性的解决方案来满足现场不断成熟和条件的不断变化;紧凑的模块化仪表设计很容易实现现场改制,从而更简化了客户的现场安装和调试,以及根据运营商的资本支出和不同的工况要求而实现定制。
“The MPFM 2600 M is designed to help operators manage costs and increase efficiency while enhancing production and making smaller fields more viable,” said Patrick Babka, vice president and general manager, Roxar, Emerson Automation Solutions. “It is also ideal for applications requiring one multiphase meter per well, allowing operators to track multiphase flow from all of their individual wells accurately and cost-effectively.”
“MPFM 2600 M 旨在帮助客户控制成本和提高效率及产能, 并使较小的油田可以更好地运营下去。”艾默生自动化解决方案Roxar副总裁兼总经理Patrick Babka表示,“对于每个油井需要一个多相流量计的应用来说,这款流量计是理想之选;通过该流量计,操作人员可以精确、成本经济地追踪来自各个井口的多相流。”
The MPFM 2600 M can identify and measure non-symmetrical flow in varying flow regimes, providing improved measurement uncertainty monitoring and reliability. The meter includes the advanced signal processing, field electronics and electrode geometry innovations of the third generation MPFM 2600.
MPFM 2600 M 可以识别和测量各种流场条件下的非对称流,并提供改良的测量不确定度和更好的可靠性。和第三代MPFM 2600 多相流量计一样具有先进的信号处理技术,以及创新型现场电子部件和电极形状。
Different modules can be placed into a variety of configurations and software modules are available to help with challenging applications including flow back measurements, well testing and allocation metering. These customized configurations include a venturi which extends the operating range of gas void fractions (GVF) to 100% (MPFM 2600 MV), a compact gamma system for improved accuracy (MPFM 2600 MVG), a formation water salinity measurement system, and a special operating mode for wet gas wells.
不同模块可以进行多种配置,并且提供软件模块用于挑战性应用,包括回流测量、油井测试以及分配计量。这些定制的配置包括一个可以将其气体孔隙率(GVF)的工作范围扩展至100% 的文丘里管,一个可以改善精度的紧凑型伽马系统,一个地层水盐度测量系统以及一个适用于湿气油井的特殊操作模型。
关于艾默生
总部位于美国密苏里州圣路易斯市的 Emerson (纽约证券交易所股票代码: EMR),是一家全球性的技术与工程公司,为工业、商业及住宅市场客户提供创新性解决方案。艾默生工业自动化业务通过业界领先的技术和工业专长,帮助过程和离散制造商实现自动化并优化生产过程。艾默生商住解决方案开发一系列技术和服务,从而改善人类舒适度,保障食品安全,保护环境,实现可持续性的食物垃圾处理,并为各类建筑和市政基础设施提供高效的建设和维护支持服务。如欲了解更多信息,欢迎访问:www.Emerson.com.cn
